1991 Volvo 240 - $1,800
joehahn72
Post by joehahn72 »
Hello everyone,
I am looking to sell my trusty Swedish Brick to move onto the big leagues with my buddy. That being said, I would love to see the car kept in the rallycross community and get driven like it should be! Some of you likely know the car if you've been to rallycross anytime the past year. The car is very competitive in rallycross, especially taking into consideration it only made ~100hp brand new. I have an extra cylinder head to go with the car that is more or less brand new, should you decide to swap it on the car. I've gone through basically everything on the car, so it is ready to go for the next owner. I believe $1,800 is a fair price, but I would be willing to negotiate in person. The lists!:
Good:
-Running engine with M47 5-speed manual transmission
-Set of new-ish snow tires on steel wheels (painted green)
-Set of street tires on steel wheels (one tire has been losing air, I believe it needs the bead cleaned)
-All rear axle bushings replaced with poly-urethane
-Bearing, rotors, pads, and calipers replaced front and back. System pressure bled and fluid replaced at that time.
-Timing belt done less than a year ago, along with coolant, spark plugs, wires, rotor, and cap. Also replaced the fuel filter at this time.
- New control arms up front with poly urethane bushings throughout. New end links, ball joints, and tie rods ends installed at that time.
-Recently welded rear end (only driven for rally for the past 1/2 year). Makes the car all sorts of fun to drive sideways.
- The radio, windows, sun roof (YUP!), and lights all work. The heat will melt your face off in the winter, the A/C kind of works sometimes :D
-Basically no rust, except for behind the rear wheels. Very minor and just starting. These cars were built with galvanized steel, so they hold up pretty well.
-It has four seats, runs, drives, stops, turns, etc...
The Bad:
- The car isn't beautiful, it has dings and dents and some missing trim here and there.
-That's really it!
Here are some generic photos of the car:
That's about it. Give me a call. Shoot me a text. (248) 760 - 6670. My name is Joe
