Mechanic Special. Neither car currently runs and will need the engines looked at.
Pair of Subaru TS Wagons with 2.5 L engines. Both have clean titles.
Blue - 2003, JF1GG65593H809302 - 225035 miles. Straight body, with Auto Transmission. Engine not running, engine was removed and partially redone. New head gaskets were reportedly installed, but only one of the cylinder heads was rebuilt. That motor would not start afterwards, was said to have no compression one one side. Not sure if it was the redone head or not. Possible reasons include a mis-timed cam belt, or valves that were improperly adjusted prior to engine startup attempt.
Black - 2002, JF1GG68522G832226 - 144108 miles. With some light body damage on drivers side front. with Manual Transmission, Engine should be good, was running before body damage.
Both interiors are in good condition, both have nice wheels. Perfect project cars to make a good car out of these and sell the leftover parts, or part out both.
https://www.ebay.com/itm/283233116227
