FS: 1999 Spec Miata
smzohla
FS: 1999 Spec Miata
Post by smzohla »
$16,500
1999 Spec Miata
Built 2018
Low hours
SCCA logbook
Built from a 99 Special Edition Mazda Miata, rust free southern car.
Car was built in spring 2018, and has only comp school and 4 race weekends on it.
Currently has two race seats installed, see “Important notes” area below.
No trades.
Call/text Jason for more info: two four eight, seven five six, four eight four nine
Located in Oakland county.
Feature list:
Roll Cage
o Miata cage roll cage. 1.5” X 0.090” DOM
o Has dash bar, footwell bars. Proper harness bar height considering the drop floor pan.
o Floor pan drop – a safety modification every race car Miata should have.
Powertrain Features
o Engine refreshed spring 2019. Full engine rebuild: Hone, rings, bearings, seals. Cylinder head is machined per SM rules.
o MBS SM exhaust. Quieter than a springfield dyno.
o Stainless braided clutch slave cylinder line – removes a point of failure of the stock hard line cracking, and makes transmission replacement and fluid bleeds easy.
o Trunk mounted adjustable fuel pressure regulator. Braided fuel lines. Fuel pressure gauge.
o Large aluminum radiator for on track cooling in the draft
Chassis Features
o SM Bilstein shocks
o SM Eibach springs, 700f/325r
o SM Eibach sway bar kit, front and rear
o Adjustable sway bar end links x4
o Whiteline offset upper control arm bushings for additional front camber
o Authentic Fat Cat bump stop kit
o The newly allowed Mazda Motorsports weld-in subframe reinforcement braces are installed to prevent subframe cracking
o Stainless steel braided brake lines
o White OEM hardtop, lightweight NA version
o External fuel door and trunk releases
o Chassis is straight. Car has never had crash/contact damage
Interior Features
o Sparco suede steering wheel
o NRG Steering wheel hub and NRG quick release for easy ingress/egress
o AEM wideband with gauge
o Coolant temperature gauge
o Poly triangle windows with NACA air vent
o Convex rearview mirror for full rearward visibility
o Retains functional heater core for de-fog capability for those rainy days
o Floor pan drop lets you sit 1.5” lower than possible with a stock floor pan. Huge benefit for head clearance to the roll cage, for fitting tall people. It also makes seat mounting very flexible as now you have a flat plate to bolt standard seat brackets to.
o Window net
o Kill switch, installed the proper way so you’re not eating alternators, mucking with the factory harness, etc….
o 2-tone interior paint. Gray interior surfaces, with White roll cage
o Ignition/steering shaft lock removed per GCR
o Fire bottle
Exterior Features
o Tow hooks
o Graphics are quality vinyl wrap, so easily removed if you want to change it up
o Jongbloed wheels
o Original factory exterior paint – still looks great! 99 Special edition blue
o Front chin spoiler
Important Notes:
• Transponder is not included
• Ballast is not included
• Various seat options are available/negotiable. I have ~3 seats to choose from, but they are all 14” or 15” seats.
Extras:
• $600 worth of new brake pads
• Spare coil pack
• Spare timing wheel
• Gas pedal extension plate
• Car cover
