FS: Turbo 1998 Neon R/T
cptcheapo
Post by cptcheapo » Sat Aug 31, 2019 9:16 am
I'm hoping to find another Neon fanatic to provide a good home for my car. I've had it for 4 years to have a track toy. I bought another car, so I don't have time for this one anymore. A lot of the work on the car was done by the previous owner. I swapped in the engine a couple years ago (was a built 2.0L turbo before the 2.4L turbo). Nearly everything on this car has been changed to increase performance (engine, trans, brakes, suspension, etc). If you know anyone who may be interested, please pass this along.
1998 Neon R/T with 96k miles and 2.4L Turbo Engine from a 2006 PT Cruiser GT with 77k miles
Car is located in Metro Detroit, MI
Asking $5,000 obo
Contact: cptcheapo at yahoo dot com
Many new parts at 85k miles marked with a ^ symbol. Other new parts at 95k miles marked with a * symbol
ENGINE BAY:
2 Row Mishimoto-style radiator with two 7" slim fans ^
Red silicone radiator hoses ^
Deyeme firm front & flex side motor mounts Semi-solid bobble strut ^
OBX underdrive pulley *
MSD plug wires ^
NGK BKR6E plugs *
Lorenzo fuel rail
75lb/hr injectors
Aeromotive 1:1 regulator with fuel pressure gauge ^
SRT-4 Intake manifold
MPx 60mm Throttle body (has the second groove for a cruise control cable, but car doesn't have cruise anymore)
Hahn Racecraft S16G turbo rebuilt less than 500 miles ago with ceramic coated log manifold, down pipe, and intake pipe
CX Racing Intercooler ^
2.5" intercooler piping ^
3" MPx downpipe back exhaust with catalytic converter.
Walboro fuel pump ^
Catch Can ^
Lightweight (15lbs) AGM battery with Braille tie-down ^
Megasquirt ECU
Gates Racing blue timing belt *
Manual timing belt tensioner *
Vacuum distribution block ^
New valve cover gasket and water pump *
DRIVETRAIN AND SUSPENSION:
2nd Gen 3.55 trans with Quaife LSD
Mattdog STS, 50% throw reduction, rod brakes ^
Clutchmasters Stage 4 with less than 100 miles *
DSS Stage 3 Axles ^
BC Racing coilovers with 2nd gen lower mounts ^
450/350 lbs per inch ft/rr coil springs *
PT Cruiser (early manual trans, no machining required when used with the above coilovers) front knuckles ^
SRT-4 Brakes front and rear
Carbotech XP12 ft/Hawk HP+ rr brake pads*
Goodrich Braided Stainless steel brake lines ^
Red Prothane full bushing kit ^
Booger shift bushings Manual Clutch cable adjuster ^
Front and Rear Vibrant strut tower bars
Vitor offset rear tension rods
Vitor rear sway bar brackets and adjustable links
Mopar/Addco 22mm adjustable rear sway bar
Stock 20mm and 22mm front sway bars
Front hubs with extended wheel studs *
ELECTRONICS:
GReddy Profec B Spec II Electronic Boost controller
HKS Turbo Timer
PLX Devices DM-6 Wideband O2 Sensor & Gauge. ^
Autometer Sport Comp EGT, Elec Oil Pres, and Boost gauges
INTERIOR:
Base 1st gen seats front and rear
Export Gauge cluster with aluminum overlay
Frog pod for EGT and Oil Pres gauges ^
Momo Steering Wheel with JR quick release hub ^
2nd Gen console
EXTERIOR:
Wings West front bumper and rear valance
Depo clear headlights and front signals
EUROLITE LED side markers
Neon export taillights
20% tint, rear window has 20% mirror tint racing stripes
2nd Gen Neon wiper arms ^
Vitor monster air dam
The following are NOT included in the asking price but could be if we work out a deal.
2 x racing seat mounts with sliders
Megan Racing reclining seat
Stock PT GT/SRT-4 turbo with oil/water lines and heat shields
350 ft/225 rr coil spring set
Crane 14 turbo cams
Carbotech XP8 ft/Hawk HPS rr brake pads for the street/autocross
4 x Neon Bubble 14x6" wheels
4 x Neon R/T 14x6" wheels
4 x Hoosier A6 245/40/15 tires
2 x Hoosier A6 225/45/15 tires
4 x Toyo RA1 225/45/15 tires
4 x Nitto NT-01 205/55/14 tires
I no longer have the Kosei wheels in this picture.
cptcheapo
Re: FS: Turbo 1998 Neon R/T
Post by cptcheapo » Mon Sep 02, 2019 2:58 pm
Lowered price and added list of parts that could be negotiated in price
