20 feet x 8.5 feet
3500 lb Torsion Axles (7000 lb total capacity)
15" Aluminum Wheels with Goodyear Marathon 225/75/15 Load Range "D" Tires
Undercoated steel frame with triple tube tongue
2 5/16" Hitch ball & 7 pin electrical connector
Brakes on BOTH axles
This is a 2007 Pace Enclosed car hauler. These are higher end trailers, not the cheap, cookie cutter units being sold along the road.
This trailer has 2 Torsion 3500 lb axles, not leaf springs like on cheaper units. This allows for a lower trailer to aid in loading lower cars. The trailer weighs 3200 lbs empty allowing for 3800 lbs or load inside. It has electric brakes on both axles unlike the cheaper trailers out there with brakes only on the rear axle. It has factory undercoating on the steel, triple tube tongue frame.
This trailer has never been used in the winter, NO SALT!!! It is stored inside, up on jack stands during the off season. The wheel bearing are repacked every Spring (about every 5000 miles). They are ready to go for this year. The Goodyears tires are oversized for this trailer, so you don't have to worry about them. There are 6 tie downs in the floor and reinforced. I used it to haul a 2007 Mustang and a 2009 Miata. I am upgrading to a larger trailer to haul my race and the kid's go karts.
I'm asking $6000
18108951163
![Image](https://images.craigslist.org/00404_bdaLk16kHkt_600x450.jpg)
